Misfire
163,822,029 MILES • 3.4L • V6 • 2WD
SHAWN.GOULET-97
I removed the Intake manifold and used and air compressor to try and clean out the manifold and my intake. After doing this once the car gets warm and I am idling it begins to idle so rough it shakes the car, I lose all my power, my fuel mileage goes to crap and after I reach 30 mph the check engine light blinks at me. I can change the spark plug and its good for about fifteen minutes then back to running pour. I changed the spark plugs and wires. New gaskets. I am out of options and beginning to get very frustrating. I regret taking it apart to begin with because it was running good before I figured it might be good for it, obviously not.
Sep 7, 2018 at 1:28 PM
Good morning.
Did you remove the upper manifold or the lower intake?
Did you remove the injector rail with all the injectors? It may be that dirt got into the injectors and they are not sealing correctly causing a rich running condition.
Sep 7, 2018 at 10:35 PM
SHAWN.GOULET-97
Upper manifold. Did not remove fuel rail, but a buddy of mine told me when I push the little bleed thing on the rail gas should squirt out with a lot of pressure. Well I do that and gas slowly leaks out.
Sep 8, 2018 at 8:50 AM
Okay, you need to get a fuel pressure gauge and measure the pressure.
(Key ON, Engine OFF) 358-405 kPa (52-59 psi)
Sep 8, 2018 at 9:02 AM
SHAWN.GOULET-97
What happens if the pressure is not correct?
Sep 8, 2018 at 10:10 AM
The fuel pump will have to be replaced.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Sep 9, 2018 at 3:10 AM
