Misfire, jumping RPMs, water throwing from cylinder when Engine is cold?
182,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
IFRAN
My car was having a misfire. I had changed the four fuel injector, power plugs, software update but nothing helped.
Still misfiring and jumping RPMs. Water throwing from cylinder when the engine is cold. Every time I start the car in the morning it irritates me. Every morning i need to warm up the engine at least 5 to 7 minutes with RPMs at 1,000 to 1,200 for couple minutes after the Engine reaction is no problem at all.
So far, several mechanics have checked the car no one produces a long-term resolution. Please advise.
Oct 27, 2022 at 8:51 PM
  • 55,851 POSTS
When you say water do you mean coolant? Can you upload a short video of the problem so I can see what's going on? Also, we should do a compression test to see if the engine is in good shape.
and
Tune up? Trouble codes? Please give me more information so we can fix the car for you. Please go over these guides and report back.
Oct 29, 2022 at 4:43 AM
