mis fire
175,000 MILES
MDHAYNES
I have a 2001 highlander that coded miss fire's on 2,4,and 6 with a coil code as bad. I changed all the coils and plugs and still getting multipul miss fire and cylinder 2 mis fire. What else could the problem be?
May 14, 2013 at 11:07 PM
WRENCHTECH
  • 20,760 POSTS
Codes don't tell you what to change or what is bad. They merely record a specific situation that the technician has to diagnose.
What are the exact code numbers being set now and what are the symptoms?
May 15, 2013 at 12:02 AM
MDHAYNES
it codes back with p0300,302 midfire, 304 misfire, 306 mismire, 1300,1305,1310,1315,1320,1325, and 1354. Thanks
May 16, 2013 at 12:05 AM
WRENCHTECH
  • 20,760 POSTS
Are those codes current? Did you clear everything after the last repair?
May 16, 2013 at 12:34 AM
MDHAYNES
Yes several times
May 16, 2013 at 2:05 AM
WRENCHTECH
  • 20,760 POSTS
You must have a wiring or PCM problem. I'd start looking for a bad connector somewhere in the harness that feeds those coils.. You're also setting a VVT code.
May 16, 2013 at 2:32 AM
MDHAYNES
decided to get a diagnostic check to see if it might be the VVT. all wiring and connections look good. Thanks for your help
May 16, 2013 at 3:55 AM
WRENCHTECH
  • 20,760 POSTS
Somebody is going to need a lab scope to track down where that is happening.
May 16, 2013 at 4:12 AM
