2002 Mini Cooper Fan Runs After Shutdown
SIMONE DEVEREUX
I have a Mini Cooper S 2002 with 31000 miles on the clock. Recently, upon switching the engine off, the fan has started to come on and continues to whizz away for a good 15 minutes before the fan cuts off. Yesterday, the temperature guage went right up whilst trying to park - and then the fan kicked in again. It seems to be ok whilst driving normally and the temperature guage sits somewhere in the middle. I am a bit scared to drive it now in case I am causing more damage and don't really want a big repair bill. Please advise. Thank you.
Feb 26, 2007 at 11:17 PM
2CARPRO JACK
  • 11,533 POSTS
So its running hot parked or in slow traffic? Have it looked at for leaks in the cooling system.... might need a thermostat. Be sure there are no restrictions in front of the radiator( trash or other road debris)
Feb 26, 2007 at 11:43 PM
Suggested Repair
Have the cooling system inspected for leaks and a possible faulty thermostat. Also check that nothing in front of the radiator is restricting airflow.
Conversation Summary
The owner of a 2002 Mini Cooper S reports the cooling fan running for about 15 minutes after shutdown and the temperature gauge rising while parking, though it stays normal during regular driving. The expert suggests the car may be running hot when parked or in slow traffic and recommends checking the cooling system for leaks, considering a thermostat, and clearing any debris blocking the radiator.
