1977 MG Midget Rebuilding Lever type heater control valve
1977 MG MIDGET
47,000 MILES • 4 CYL • 2WD • MANUAL
1953BILL
Im in the process of putting together a new heater control water diverter valve ...lever type used in the later midgets. my question is do you put any type of gasket sealer on the two gaskets that go between the inlet and outlet part of the valve ? or do you just bolt the unit together real snug. I dont see anywhere in the shop manual where it says to use gasket sealer. Thanks for the advice.
Bill
Feb 10, 2010 at 4:47 PM
2CARPRO JACK
  • 11,533 POSTS
If you have anew gasket, it may not require any sealer.If there isnt a gasket i would use silicone to glue the two pieces together.I recommend GMS (General Motors Sealant) available at any GM dealer parts dept, it is really good stuff, pricey but good
Feb 10, 2010 at 4:54 PM
