1967 MG Midget head lamps
1967 MG MIDGET
99,254 MILES • 4 CYL • 2WD • MANUAL
DEAN MILLER
i am rewireing this car cant get head light to work why
a was trying i think i burnt out the lamp can you tell me
how to test them out of car
thanks dean
May 19, 2010 at 8:55 AM
HMAC300
  • 48,601 POSTS
first you have to know if it's positive ground or negative ground. the ground wire should go to the center spade sticking out from the headlamp. the left one if you put power to it will or should be the low beam. the right one should be the high beam. If you plan on keeping this car i would highly reccomend getting teh book by rick astley on mg electrical systems. it goes through everything there.
May 19, 2010 at 11:55 AM
