1976 MGB MG power
1976 MG MGB
100,000 MILES • 4 CYL • 2WD • MANUAL
DJOHENNING
My MG starts fine, idles fine, but when I approch a hill and the engine is under a load it wants to cut out and die. If I put the clutch in and feather the gas pedal it reves back and I can continue. It will go a little ways and then while under a load do it again. Any suggestions. Thanks Don
Oct 21, 2009 at 4:38 AM
HMAC300
  • 48,601 POSTS
first check your fuel filter. Then check fuel pressure it should be 3 #. Then if you have points in itcheck the points for gap and timing. If not any of those then maybe go through your carb checks and adjustments.
Oct 24, 2009 at 6:30 AM
