Villiager heating problem - need help
ADAM2004
I have 1998 Mercurry Villager and now it is winter
it takes a longtime to warm up. No warm air comes out of the vents until I start driving for a prolonged period. As soon as I stop, vents start blowing cold air. Same issue with the rear heater. Also sometimes the car has Water Coolant smell once van is driven with the heater on for a longtime.
Otherwise the car is normal and does not over heat.
Took it to a mechanic. The car was very low on
Coolant water. He did the pressure test. It was normal. But he noticed a leak coming from
the rubber hose on the intake manifold side.
He said this is a big job and it cost a lot since it is not
easy to get into lower rubber hose on the intake and
would need to remove lots of stuff and replace
the manifold gasket.
Does this make sense? Is there a way to replace
the intake rubber hose without changing the manifold gasket?
Feb 23, 2007 at 3:43 PM
KIN CHAN
  • 453 POSTS
gotta button up ur leak 1st b4 anything else ...if u concern about the labor rate or diagnostic from the 1st shop...try another one and chk if they come up with the same opinions ...r&r rate usaully use about the same guide for quotes ... it should not be any attributary # regardless what sex,age race gender difference.....good luck man
Feb 23, 2007 at 10:59 PM
MIKE H R
  • 3,094 POSTS
take it to another garage and ask how much it would be to change the lower hose. it seems like the reason you have little or no heat could be from lack of anti freeze and water. How does it work with the system being filled?
Feb 24, 2007 at 1:25 AM
