2000 Mercury Villager Hard Warm Start Fix
RAYONE
My 2000 Villager 3.3L (145K) is hard to start when engine is warm/Hot, however it starts great when cold from overnight. I crank for 10+ seconds and I have to pump the gas pedal to get it going. It sometimes sputters at first but otherwise runs fine.
I have replaced the Rotor, Wires, Cap and plugs recently no other sensors lately.
Any thoughts on what to check or replace?
Oct 29, 2007 at 6:28 AM
BLACKOP555
  • 10,386 POSTS
try turning the key on for 5 secs then off for about 3 times then start if it starts right up you have a bad fuel pressure regulator or check valve. repost results.
Oct 29, 2007 at 12:28 PM
RAYONE
I tried the On Hold Off and On routine this still did not seem help. I had to still step on the gas to go. However, I am not sure the Fuel Pump engages as your routine describes in the same manner on this model. So it may still be a Fuel pressure thing?
Oct 31, 2007 at 12:27 AM
BLACKOP555
  • 10,386 POSTS
if its efi yes it should engage when the key is turned. have fuel pressure tested at the fuel rail. also check and replace the fuel filter if your not getting full fuel pressure, if you still dont after filter check out the pump.
Oct 31, 2007 at 11:50 AM
RAYONE
Yes I had a mechanic verify it was a fuel pressure regulator.
Jan 9, 2008 at 5:46 AM
Suggested Repair
Have fuel pressure tested at the fuel rail. If pressure is low, replace the fuel filter and retest; if it is still low, check the fuel pump. A mechanic confirmed the cause was a bad fuel pressure regulator, so replace the regulator.
Conversation Summary
A 2000 Mercury Villager 3.3L started easily when cold but was hard to start when warm, needing a long crank and gas-pedal pumping before it sputtered and then ran normally. Recent ignition parts had not fixed it. The expert suggested a key-on prime test for a fuel pressure regulator or check valve, then a fuel-rail pressure test, fuel filter, and pump check. The owner reported a mechanic confirmed a bad fuel pressure regulator.
