1999 Mercury Villager speedometer sensor
1999 MERCURY VILLAGER
111,500 MILES • 6 CYL • FWD • AUTOMATIC
DONNA DEVOE
how do i remove the old sensor
Mar 10, 2010 at 1:50 AM
  • 110,244 POSTS
Here is what I was able to find.
Disconnect the negative battery cable.
Raise and safely support the front of the vehicle securely on jackstands.
Disconnect the VSS electrical connector.
Remove the VSS hold-down bracket bolt and remove the bracket.
Remove the VSS from the vehicle.
The installation is the reverse of removal. When installing the VSS hold-down bracket, tighten the bolt to 44-61 inch lbs. (5-7 Nm).
Let me know if it helps.
Jun 10, 2010 at 2:56 AM
