Cylinder 1 and 3 does not firing. Engine code is PO300. The dealer said the injectors 1 and 3 are bad. I changed all the injectors on the rear bank (cyl 1, 3 and 5) plus spark plugs, wires, dist cup, rotor etc and also tried with another distributor and the problem continues.
The cylinder 1 and 3 not working, there are good spark and compression but I think the 1 and 3 injectors are not injecting fuel.
Please help
SPONSORED LINKS
Wednesday, December 26th, 2007 AT 5:37 PM
