1997 Mercury Villager 1996 Mercury Villager Skips Third Gea
TRAVISTARPY
  • 1997 MERCURY VILLAGER
  • 6 CYL
  • FWD
  • 145,000 MILES
I purchased a 1996 Mercury Villager with a transmission problem.
It shifts from 1st gear to 3rd gear.
It never goes into 2nd gear or overdrive.
I will not shift manually into 2nd gear if you "pull it down."
I need 2nd gear for those steep hills here in TN.
I replaced the TCM and the shifting solenoids on the valve body but still have the same trouble.
I noticed that the previous owner replaced the TPS at some point.
Should I just try a new valve body?
How do I check the transmission codes?
Monday, November 8th, 2010 AT 2:26 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Really need to have trans scanned for codes that may provide a fault. Suspect 2-4 shift band failure can have band adjusted. Take to trans shop hav ethem check for codes if none have then adjust 2-4 Band.
Let me know
Thanks for donate
Monday, November 8th, 2010 AT 2:52 PM
TRAVISTARPY
Should I Do this even though it never shifts into those gears?
Seems electrical to me?
Wednesday, November 10th, 2010 AT 2:14 PM
