1994 Mercury Villager drive belt - compressor
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
TALKTALKCAR
  • 6 POSTS
Can't find the idler pulley bolt that I need to loose before loosing the adjusting bolt. There is no bolt on the pulley, only a rounded head in the middle.
I need to remove the drive belt connected to the compressor
Thanks
Aug 3, 2010 at 3:13 PM
2CARPRO JACK
  • 11,533 POSTS
Check the back of it, If I remember correctly the nut is on the back of the pulley assembly, then you will be able to use the tensioning bolt to loosen and replace the belt
Aug 4, 2010 at 9:30 AM
TALKTALKCAR
  • 6 POSTS
thank you for your reply. I just got back from out of town.
There is nothing behind the pulley assembly that I can turn, except for the adjustment bolt.
On the front side in the middle of the pulley, there is a flat circular end, not a bolt that I can turn.
I tried to take a picture for you but can't get a good shot due to tight space.
Looking forward to your feedback. thanks
Aug 10, 2010 at 12:30 PM
2CARPRO JACK
  • 11,533 POSTS
There has to be something holding the pulley.See if possibly the flat front piece is a cover for a bolt.Also make sure that isnt an idler pulley. and the accessory is what moves, but im pretty sure the pulley is the tensioner
Aug 12, 2010 at 1:09 AM
