1993 Mercury Villager Positive battery cable with connector
1993 MERCURY VILLAGER
230,000 MILES • 6 CYL • FWD • AUTOMATIC
SOLUTION4U
I believe there was a loose connection between the connector on the positive battery cable and the cable. Would that cause the following symptoms:
Battery light on
Emergency Brake light and ABS light on intermittantly
rpms waver between 400 and 900 then die when put into drive
After tightening the connection it seemed better, then when turning on the headlights, the rpms dropped and wavered again.
If it isn't the connection, what else might it be? Alternator?
Please help, van is stranded on the side of the street.
Adam
Oct 12, 2009 at 8:21 AM
IMPALASS
  • 3,112 POSTS
Hello –
Is your model the GS, or LS and what is the engine size in liter?
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can bring their tester out and check your battery and alternator. Make sure your battery is fully charged.
Oct 12, 2009 at 10:28 AM
