1993 Mercury Villager Misfires
NINAMONICO
  • 1993 MERCURY VILLAGER
Engine Performance problem
1993 Mercury Villager 6 cyl Front Wheel Drive Automatic
I changed catalytic converter, airflow meter, spark plugs, d-cap, rotor cap, gas filter and tuned-up. Every time the car is driven 10 minutes or engine warms up it begins misfiring, choking, looses power until it turns off. I have to let it cool off for 30-60 minutes before it can start again and drive. What is going on? Can you help?
Monday, March 23rd, 2009 AT 4:51 PM
RACEFAN966
  • 5,029 POSTS
Ok it sound like you may have a module problem. Now what needs to be known is weather or not you have spark when it dies and won't start. Do you have a digital multi meter to use? Get back to me with the needed info and we will go from there.
Tuesday, March 24th, 2009 AT 10:43 AM
MS.SELVIE
I have the same year van 1993 mercury villager and it does the same thing, after so long it misfires an evenually shuts off and won, t restart until it cools off. I have replace a sensor the the egnine control module. Took it to shop they scoped the computer system and said it needs a distributor and also said that the ignition pattern is very erratic, and that it may have a damaged computer. What do you think?
Tuesday, March 24th, 2009 AT 12:03 PM
NINAMONICO
Check the car distributor thats what we finally the shop working on our car found that it was.
Thursday, May 7th, 2009 AT 3:50 PM
