1993 Mercury Villager low oil light came on and car stopped
1993 MERCURY VILLAGER
144,016 MILES • 6 CYL • FWD • AUTOMATIC
CHERYL PRIER
i've checked the battery, fuses, gas filter. everything seems fine. i was driving and felt like i was losing power, i pulled over and the van died. will not start. the low oil light comes on when i try to turn it over. ive never seen it come on before. im wondering if the van wont start because the computer or brain thinks its low on oil. what do i do? and yes i checked the oil level, its fine. please help me.thank you, cheryl prier.
Aug 26, 2010 at 6:46 AM
LEGITIMATE007
  • 5,121 POSTS
first you 'll need to check for fuel pressure , and spark.
does it try to turn over? once you check for spark and fuel , we will then know which direction to go. I kinda suspect the crank position sensor, but i'd rather be for sure than throw parts at it. i'll show you how to do it with the "links" that I send you on the subjects.
Aug 26, 2010 at 6:53 AM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
CHERYL PRIER
Thank you for your response. yes there is fuel presure and spark. It does try to turn over, but wont. please advise me as what to do next. you can call me if you want. 360-853-7182. thank you cheryl prier...Hagd
Aug 27, 2010 at 4:10 AM
LEGITIMATE007
  • 5,121 POSTS
ok it has to be missing one of four elements, spark,fuel,compression, or air. how is the air filter is it dirty? replace it if it is. also the mass airflow sensor may be bad, you could have a broken timing belt. which would lead to no compression.
Aug 27, 2010 at 5:40 AM
