1998 Mercury Tracer My car won't start
1998 MERCURY TRACER
136,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANGIEB4523
My car started with a jump but when I was driving it home the lights were on and I went to use my turn signal, the lights dimmed way down like the car was going to die (this is after the jump). I have let the car sit and now when I try to start the car its makes 2 starting noises and then nothing. I tested the battery using a digital multimeter and the results are as listed: Just the battery itself was 12.34volts. Then I tested the battery with the key in the on position and it was 9.74volts. Next I tested it with the key in the on position and the head lights on and it was 8.9volts. And last I tested the battery with just the lights on and the car off, it was 9.65 and slowly dropped to 9.31 volts. I checked the fuses under the hood and the spark plugs. My car still won't start. I'm stuck any suggestions? I recently replaced the fuel pump, filter, oil pump, oil, and filter, the timing belt and the air filter. Please help, all suggestions are welcome and appreciated. Thank you!
Apr 15, 2010 at 5:21 PM
