1989 Mercury Tracer fuel
1989 MERCURY TRACER
94,567 MILES • 4 CYL • 2WD • AUTOMATIC
JRJONES4DUB
I first noticed my fuel guage not always reading on the dash, it did this for about 2 weeks and one day on the way home it just stopped as if I ran out of gas, now the tank was filled the night before. Well it would not start nomatter what. I checked for sparks from all distributers and coil overs( they are good) I change fuel filter and then it started and drove about 2 miles just fine and then started doing the same thing. The difference is that I could start it every now and then. So i put a new fuel filter a few days ago, same thing. Worked for about 30 min and went out again. I notice anytime I really try to accelerate the care chokes or dies. If it is in nuetral I can rev. it to redline without any problems, but the second I put in drive, CHOKE or DIE!. Please advise. Thanks
May 23, 2009 at 4:36 PM
Check the fuel pressure it should be 64-85psi to rule out the fuel pump and regulator
May 23, 2009 at 5:20 PM
