1992 Mercury Topaz idel
1992 MERCURY TOPAZ
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
SALLY22980
seems to idel fast and when cut engine off makes a blowing whistle sound
Dec 19, 2007 at 8:31 AM
KWEED
You should check to see if you have a vacuum leak. To do this Turn it on and leave it in park then spray the vacuum hoses down with a parts cleaner of some sort. If the engine speed slows and starts blowing white smoke out the tail pipe you've found the location of the leak. I would advise not using starting fluid because of its likely hood to catch fire and or explode.
Feb 12, 2008 at 5:29 AM
