Erratic starting
MERCURY SABLE
SABLETROUBLE
1992 Sable, 3.0. Engine starting erratically. Always turns over, but does not always fire. Happens mainly in cold. When it does start, it often dies shortly after starting (periodically). It then has to be towed back and let to sit. Will start again when it feels like it. Fuel pump pressure checked okay. Spark checked in plugs and is okay. No error codes pulled up in diagnostic, none recorded.
Direct response to e-mail okay at quinnproc@aol.com
Rick
Jan 22, 2007 at 10:24 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
All I can think of is change the fuel pump relay and see if it helps. it's in the power distibution box near the radiator. The contacts might be sticking!
Mar 5, 2007 at 4:18 PM
