2004 Mercury Sable drive belt or serpantine belt
2004 MERCURY SABLE
120,000 MILES • 6 CYL • FWD • AUTOMATIC
ATARA20
my belt that connects to the water pump, and air etc. came off. how do i replace it
Mar 29, 2009 at 2:07 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, There is what is call a belt tensioner assembly, you will need to use a special tool in order to move the tensioner so that the belt can be reinstalled. However, there may be a problem if the belt just came off and you should have it checked. Take a look at the link below and find the set up for your vehicle and it will give you the location of the tensioner assembly. https://www.2carpros.com/car_repair_information/year/2004/make/mercury/model/sable/2004_mercury_sable_drive_belt_routing_diagram.htm Here is the special tool that will make it easier to get the belt back on....
https://images.2carpros.com/forum/automotive_pictures/188069_24947_8.jpg
Mar 29, 2009 at 2:33 PM
ATARA20
thank you so much...that helps a lot. if i have any other questions i will be contacting you shortly
Mar 29, 2009 at 2:42 PM
