2001 Mercury Sable Dim lights, dead battery
2001 MERCURY SABLE
94,000 MILES • 6 CYL • 2WD • AUTOMATIC
MADDOG75
  • 11 POSTS
The problem started out with the loss of power to the engine, EBS brake and low gas light coming on and the radio not working. Also noticed that the interior lights were dim. The car would do this intermitantly untill the battery was dead. I repaced the battery and 1 week later the same problem. Im thinking its the alternator but I wanted some other opinions or maybe a test that I can perform on alternator. Any ideas?
Nov 3, 2008 at 10:07 AM
SERVICE WRITER
  • 9,123 POSTS
Try this
https://www.2carpros.com/how_to/how_to_test_alternator.htm
test procedure
Nov 3, 2008 at 10:33 AM
MADDOG75
  • 11 POSTS
[quote:0cfb3767f1="Service Writer"]Try this
test procedure[/quote:0cfb3767f1]
I read that procedure earlier and I notice that it checks the voltage but what about the amps that the alternator puts out? Can the volts be good but the amps not and if so how would I know without a test to run?
Nov 3, 2008 at 1:48 PM
SERVICE WRITER
  • 9,123 POSTS
Re-check the alternater test, I've been told it was updated.
Nov 5, 2008 at 10:36 AM
