2000 Mercury Sable
MAXWS
  • 2000 MERCURY SABLE
  • 6 CYL
  • 160,000 MILES
A few months ago I lost heat in the car so I checked the coolant and saw that it was low. I added some more and the heat went back to normal in the car. After a week, I lost heat again and I saw that it need more coolant. I checked for a hose leak and found nothing. Also the engine had been operating at normal temperature. A few days later, the car stalled and although I was able to make it home, the car ran poorly and hotter than normal. I understand that this might be a blown head gasket, but it doesn't seem to have very many symptoms (no smell, no coolant or water in the oil, no smoking). I'm assuming the car has lost manifold vacuum because I lost power in the brakes. I was told it might be the intake manifold gasket, but if this is the case, where is all the coolant going? Thanks for any help you can give.
Monday, May 3rd, 2010 AT 4:09 PM
2CARPRO JACK
  • 11,533 POSTS
I would have the cooling system chemical tested for the prescence of exhaust gasses.I have seen many head gaskets that didnt have the "Typical" symptoms. If you have coolant loss and no leaks, the engine is most likely eating it.A chemical test isnt 100%, but it is pretty close.
Tuesday, May 4th, 2010 AT 8:13 AM
