1999 Mercury Sable fuses
151,000 MILES • 6 CYL • FWD • AUTOMATIC
BELLONI890
  • 9 POSTS
Where are the fuses located that would keep the engine from starting? It cranks fine but before I do the Cam Pos. Sensor I would like to make sure its not a fuse that you say will keep it from starting, or mif it is a fuse would it crank?
Jun 17, 2010 at 2:17 AM
BMRFIXIT
  • 19,053 POSTS
Bad Cam sensor would set a code but engine should start
Check for codes
check for spark
check for injector pulse
check coil
with key on should have check engine light on if not use a test light and check fuses and relay
Jun 17, 2010 at 11:33 PM
