1996 Mercury Sable Wont move
1996 MERCURY SABLE
SKIDDERBOY
Transmission problem
1996 Mercury Sable 6 cyl Front Wheel Drive Automatic
When you put the car in drive the car will not move or go forward or reverse. The service code was PO500 will this cause the car to act this way.
Jan 30, 2009 at 8:36 PM
Try inspecting the shift linkages
P0500 OBD-II Trouble Code
Technical Description Vehicle Speed Sensor Malfunction
What does that mean?Basically this means that the vehicle's speed as read by the Vehicle Speed Sensor (VSS) is not working properly.
SymptomsSymptoms may include:
loss of anti-lock brakes
the "anti-lock" or "brake" warning lamps on the dash may be lit
the speedometer or odometer may not work properly (or at all)
your vehicle's RPM limiter may be decreased
the shifting of an automatic transmission may become erratic
other symptoms may also be present
CausesA code P0500 may mean that one or more of the following has happened:
The Vehicle Speed Sensor (VSS) is not reading (functioning) properly
There is a broken/frayed wire leading to the vehicle speed sensor
Jan 30, 2009 at 9:07 PM
