1996 Mercury Sable brake pad fell out
1996 MERCURY SABLE
KRISTIN.FULLMER
Brakes problem
1996 Mercury Sable 6 cyl Automatic 256,xx miles
I have needed rear brake pads for awhile, and the day b4 i was going to have them done one brake pad on the drivers side just fell out and my brake pedal went rite to the floor. Could this be the brake master cylinder or the proportioning valve??
Jul 20, 2009 at 3:38 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
That would be the caliper...if the pad falls out there will be too much space between the rotor and the caliper piston, tow it to the shop, DO NOT DRVE!
Jul 20, 2009 at 3:48 PM
MVORTEX1
  • 5 POSTS
If your brakes have worn to the point where parts are falling out you're way past due my friend! Merlin is right, however he didn't answer your second question which really serve the opposite of what this site offers which is avoiding trips to the shop and saving money. If the brake caliper fell off and the pedal went to the floor then you must have lost wheel cylinder pressure. You'll know this especially if you have brake fluid leakage and it will be noticeable. You should replace the brakes as well as the wheel cylinders since you waited so long - not only do they often go bad after about 50K but once you lose a component under pressure it will usually blow the cylinders right out of the gaskets. They are only about $15 a set so it's worth it and much safer than trying to re-pack them. Another important mention is that your vehicle likely has the type of rear brakes which have parts that need to be machine pressed on. These a real pain not only to get apart but to press back on evenly; Ford Motor Co is notorious for difficult brake replacements so if you haven't done many jobs like this before I would agree with Merlin and take it to shop with the appropriate tools for the job.
Aug 3, 2009 at 12:39 PM
