1995 Mercury Sable 1995 Mecury Sable Transmission
1995 MERCURY SABLE
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCOTDLANGE
When shifting gears the car hesitates for about half a second in neutral before it locks in to the new gear. The check engine light is off when the car starts, but it comes on as soon as it changes gears. If the car is accelerating slowly the hesitation can't really be felt, but if it is accelerating a little more quickly (not flooring it) you can feel it pull back during the hesitation. The handbook says that the check engine light comes on when a problem with the power train is detected. Beyond the probable cause, is further damage being done if it is driven as is?
Oct 9, 2008 at 3:18 PM
JAMES W.
  • 2,394 POSTS
Without knowing why your check engine is coming on I really can't advise you as far as continued driving. I would highly recommend you get your ECM scanned to find out what trouble code(s) are putting the CE light on. Many parts stores will let you use one for free. Most of the time they will do it for you. You get the trouble code(s) and we can go from there.
Oct 9, 2008 at 5:03 PM
