1986 Mercury Sable heater not working
KRISTA KARLSSON
Heater problem
1986 Mercury Sable Front Wheel Drive Automatic 87,850 miles
The interior heat has gradually stopped working. I found that if I had the heat turned to off when I started the car, and then turned it to defrost after it was warm I would get a little heat. Now it does not mater what I do there is no heat.
My question: How do I determine what is wrong? Or do I just replace a part, and if so, what do I replace.
Thank you—Cold in Seattle
Dec 13, 2007 at 9:51 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2125f362c7="Krista Karlsson"]Heater problem
Thank you—Cold in Seattle[/quote:2125f362c7]
check your coolant level and adjust if needed
check the thermostat
and if all good you need the heater core flushed
Dec 16, 2007 at 6:49 AM
KRISTA KARLSSON
Thank you so much for taking the time to answer my question. I will let you know my results after following your advice.--Krista
Dec 16, 2007 at 11:30 AM
