1966 Other Mercury Models stalls when i touch the gas
1966 MERCURY
20,100 MILES • V8 • 2WD • AUTOMATIC
MRAST26
1966 mercury parklane 6.7 ltr. 410 marauder.
my car stalls when ever i try to accelerate.i have tried everything and just cant get it right, would an exhaust manifold leak cause this?
Oct 1, 2010 at 1:09 AM
HMAC300
  • 48,601 POSTS
unless you tell us what you have done instead of "tried everything" then we don't know what you'vedone. I would suspect athat your car needs a carb overhaul as the fuel made today and carries alot of alcohol in and it has screwed up your accelerator pump and power valve. the newer kits have different materials that will accept thenewer fuels. Other than that check your ignition area, thesedistributors were good for wearingvacuum diagphrams where they connect to thedist plate, as well as thedist plate would wear the pin as well as the bushing in it effecting your point movement during acceleration....
Oct 29, 2010 at 5:56 AM
