1997 Mercury Mystique Raw Gas Smell & bad mileage
1997 MERCURY MYSTIQUE
210,000 MILES • 6 CYL • FWD • AUTOMATIC
KSPINNER
We get a strong raw gas smell only during the warm weather when we are driving. You can not smell it when the car is stopped, parked or when it is cold out. Also it doesn't smell all the time. We cannot see any gas leaks. We are also getting very bad gas mileage. What could be the problem and what would be the cost to fix it?
May 26, 2009 at 3:36 PM
Running rich:
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
May 26, 2009 at 3:47 PM
