1995 Mercury Mystique Engine fan not working
1995 MERCURY MYSTIQUE
DEANNA1973
Engine Cooling problem
1995 Mercury Mystique Automatic
My car is overheating and the engine fan is not working. After the thermostat was replaced the fan started working. However, a few months later, the fan stopped working and the car started overheating again. The thermostat had been replaced a year prior. Could there be something causing the thermostat to stop working? Also is this the reason the engine fan is not working or could something else cause the fna stop working?
Aug 12, 2010 at 3:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ultimately the powertrain controle module (PCM) controls when the fans should come on and off, the engine coolant temp. sensor may be faulty though. is the check engine light on ?
Oct 18, 2010 at 12:04 PM
