I have the same problem with my 97 Mountaineer on the rear driver’s side door. I've noticed it gets jammed every time my 7 year old son tries to open the door without the door being unlocked.
The first time it happened I tore the door apart from inside the truck, a difficult feat since I had to remove the back seat to get into it. I was able to manually jiggle the link for the lock that combined with alternating the electric locks between locked and unlocked freed it up.
The second time it happened I got a little perturbed and started beating on the outside of the door on and just below the handle while I was alternating the power locks and low and behold it was enough to free the lock.
To this day I still use this method when the problem occurs and I still haven’t tried to find a permanent solution since I don’t drive this vehicle except for bad weather or utility purposes.
If you find out how to fix it please let me know.
[quote:707e4f2e8d="art112597"]Interior problem
1997 Mercury Mountaineer V8 All Wheel Drive Automatic 170000 miles
Both back passanger doors locks are jammed. I cannot open the doors and they do not have key entry. Any suggestions on how to unlock them? If I can unlock them, my hope is to disconnect the power lock and just lock and unlock mannually.
I saw on another posting the suggestion of using a slim jim to pop the lock. Where can i get one of those?
thanks[/quote:707e4f2e8d]
Jan 27, 2009 at 4:13 AM
