1999 Mercury Marquis i got the code 181 fuel temperature se
1999 MERCURY MARQUIS
99,300 MILES • V8 • 2WD • AUTOMATIC
LABATTBLUE18
when i read the code 181 say range perfomance what i can be need to change sensor or something for the 442 i all ready change the gas cap the code come about every 160 miles after i fill the tank and i erase the code again the car just knine esitates between 45 and 53 miles a hours when you flooring it every thing is fine thank you for your help sincerely roland
Jul 12, 2010 at 3:02 AM
KHLOW2008
  • 41,814 POSTS
Hi Roland, Thank you for the donation. Here are the description of the problem and I have emailed the diagnostic files to you. For any correspondence just post reply here and I will be notified.
https://images.2carpros.com/forum/automotive_pictures/192750_P0181_1.jpg
Jul 13, 2010 at 5:29 AM
LABATTBLUE18
BUT ALOT PEOPLE SAY IS THE EGR VALVE NOT WORKING PROPRELY YOU DONT AGREE
Jul 13, 2010 at 9:17 AM
KHLOW2008
  • 41,814 POSTS
You are having a code P0181 so that is what you should be checking for. Erase the trouble codes. Test drive and retrieve the trouble codes again. If the code is P0181, then you need to check according to what the manufacturer recommends.
If the EGR is not working, then it should have the EGR code.
Jul 14, 2010 at 1:51 AM
