1994 Mercury Marquis loud humming noise
83,000 MILES • V8 • 2WD • AUTOMATIC
PMO22
My 1994 grand marquis is making a very loud humming noise coming from under the hood. It sounds like a air plane or rumble strips on the side of the highway. It occurs after my car is warmed up. It makes the noise at all speeds and turns. It will even do it when my car is idling. When I tap the gas peddle it will stop making the noise but will continue soon after that. I�ve had it in for this reason three times and they found nothing
Aug 18, 2009 at 4:23 AM
WINEBURGER
  • 82 POSTS
it sounds like you have a need for a clutch fan
Aug 18, 2009 at 4:30 AM
PMO22
Is there any way to know for sure if that is my problem. Any tests i can do before i spend the money on a new fan clutch?
Aug 18, 2009 at 5:17 AM
WINEBURGER
  • 82 POSTS
get the car warm with the hood up accelerate to 2000 rpm hold it there till the noise starts it will come from the fan area if thats the problem and will sound like an airplane
Aug 18, 2009 at 5:52 AM
