2005 Mercury Mariner Replacing just the brake pads
42,000 MILES • 6 CYL • FWD • AUTOMATIC
MANNYP
I have about 42000 miles on my Mercury Mariner and I know I am going to need to replace the front disc brakes soon. I have always wondered whether I could just replace the pads and continue using the rotors that are there. They are still in good condition. Can someone advise whether this is ok to do? If not, what would happen?
Nov 18, 2008 at 7:38 AM
  • 31,937 POSTS
Hi there,
It is a good idea to have the brake rotors skimmed, this can be done on site and on the car, your rotors do have a minimum thickness and they should be replaced if they are under size, the machining is not mandatory, but if you have any pulsation or steering wobble when braking, this will normally cure it. New rotors are not all that expensive these days and many opt to replace them with every 3-4 pad set change.
mark (mhpautos)
Nov 18, 2008 at 7:50 AM
MANNYP
What is skimming? I have never heard of that term before. Where can I have that done? Braking is still very smooth, no pulsing or wobble, so it sounds like just doing a pad change would be ok.
Nov 19, 2008 at 6:42 AM
  • 31,937 POSTS
Hi there,
Skimming is just machining a fraction off the disc, often the old pads will have caused some hot spots and glazing on the rotor, if you don't machine them back you may have some brake squeal, but this can be done later if you don't want to do it now.
mark (mhpautos)
Nov 19, 2008 at 7:45 AM
