The problem is i can fill up the tank, and the LCD will show that i have 450+ Miles, when it gets to 1/4 Tank if i make any sort of sharp left turns the engine will bog down, or cut out completely, and now even without making any turns when it gets to 1/4 tank it will go from having 100+miles on the LCD to having 60-50 miles, to the Low Fuel Warning light coming on and it having only 2 Miles left on it.
I am wondering is this a bad fuel sensor, or maybe something is just loose inside the gas tank. I know the access panel for the fuel pump and what not is under the rear seat.
Thanks for the help guys.
Nov 1, 2008 at 9:28 AM
