2001 Mercury Cougar Engine Misfire
2001 MERCURY COUGAR
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
TANDER311
I have 2001 Mercury Cougar, the check engine light came on flashing around 100,000 miles and started to shake and jurk . I had the spark plugs changed and that seem to fix it for a while, but it started to shake and jurk really bad again and the light started to flash again. It is still reading cylinder one misfire so the cooling pack was changed. The problem is still happening but not as bad. Mostly when I accelerate slowly. What could be the problem?
Apr 23, 2009 at 7:53 PM
BMRFIXIT
  • 19,053 POSTS
Misfire cylinder # 1
check plug, wire ,coil
fuel injector and do a compression test
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 23, 2009 at 11:16 PM
JAYBIRDJR
Mine did the samething. Make sure you replaced the sparkplugs with the OEM plantinum sparkplugs.
May 3, 2009 at 12:44 AM
