1997 Mercury Cougar Power steering pulley removal
1997 MERCURY COUGAR
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
WEMERTZ
  • 12 POSTS
Attempting to remove water pump.
Needing to remove power steering bracket from WP.
Appears to have extremely large Hex type set screw or bolt that holds pulley on. I have tried securing pulley and using breaker bar to loosen this bolt in both directions. My question is: How does this pulley come off? If I use a puller on it, how would I ever press it back on? It would seem that this center bolt should come off and then the pulley slides off, then the bracket comes off, and then I can remove the WP. I am at a stand still until I know for sure the proper removal method.
The pulley is plastic, so I can not use heat on it.
Please advise.[img:2ff4e5a169]http://www.2carpros.com/forum/automotive_pictures/94859_power_steering_pulley_1.jpg[/img:2ff4e5a169]
Oct 18, 2009 at 2:32 AM
MATHIASO
  • 1,209 POSTS
you will need a pulley puller and installer autopart or autozone have those. the pump and pulley must be remove from the vehicle and installed in a wise, then use the tool below.the instruction is with the tool.
https://images.2carpros.com/forum/automotive_pictures/46384_pullry_puller_1.gif
Oct 18, 2009 at 3:07 AM
WEMERTZ
  • 12 POSTS
The manual for the car states just remove pulley and slide off bracket. Not removing half the engine compartment to get power steering pump out and onto a vise.
I have all pullers and bearing set tools.
I still do not see proper method for removal.
Oct 18, 2009 at 3:23 AM
MATHIASO
  • 1,209 POSTS
do you have the one in the picture?
I'm sure you do.
at any autopart, they have free green small brochure at the entrance of the store, take the one with power steering removal and intallation.
that will guide you,
the wise you have on the bolt in the picture will just make the removal process more difficult is striped or damaged.
Oct 18, 2009 at 3:54 AM
WEMERTZ
  • 12 POSTS
Think about this:
I am trying to remove the water pump.
In order to do this, I must remove the power steering pulley as the car manual states in order to remove the power steering bracket attached to the water pump.
The manual does not state taking the power steering pump out of the vehicle.
If I did remove the pump/pulley/bracket onto a vise, press, etc. there would be no need to remove the pulley because the bracket would already be off the water pump!!!
Any other suggestions?
Oct 18, 2009 at 4:06 AM
MATHIASO
  • 1,209 POSTS
Some 1989 and later models require the removal of the pulley from the pump.
the pulley can be removed right there with the use of the tool the picture above.
Oct 18, 2009 at 4:21 AM
