Where is the OB2 plug scanner located on a 1994 Mercury Cougar?
What are the probable causes to this type of engine
problem? What are the possible solutions?
Tuesday, June 16th, 2009 AT 8:05 PM
BLUELIGHTNIN6
MECHANIC
Your data link connector (DLC) is located at the right side of the engine compartment. There are way too many things that will cause an engine light to illuminate. You will have to retrieve the trouble codes in order to pinpoint the culprit.
SPONSORED LINKS
Tuesday, June 16th, 2009 AT 9:00 PM
SPORTSSUMMARY
MEMBER
On my car it is located underneath the glove
compartment.
