1993 Mercury Cougar Odometer
1993 MERCURY COUGAR
167,000 MILES • 6 CYL • 2WD • AUTOMATIC
AWSHAFFER
My odometer and trip rest do not work. I replaced the sensor on the transmission
Nov 9, 2008 at 8:36 PM
MCZB
I had the same problem with my car. I found the problem on a web site. www.eastcoastrollingthunder.com/smf/index.php?topic=228.0
You can order a replacement gear to replace the broken one. The factory ones are very brittle and brake easly if you press the reset button while moving. I recieved my part in 5 days. www.supercoupeperformance.com/partBrowser.aspx?partId=493
One word of caution though. Be carefull pulling off the needle. It bends and breaks easily. Good luck!!
Nov 13, 2008 at 1:39 PM
