1992 Mercury Cougar gas smell in my oil
JOJO8705
Smells problem
1992 Mercury Cougar 6 cyl Two Wheel Drive Automatic
well for one thing when it rains or it is cold out my car wont start it tries to but it wont and also my friend and i were trying to figure out what was wrong and i pulled out my oil dipstick to check my oil and it smells like gas and its not as thick as it should be and its very shiny and clear and i have changed my oil recently. i didn't know if maybe i need to change my plug wires or maybe its because i only drive to work and back and its 4 blocks away and my car doesnt have enough time to warm up or what it could be.
Oct 22, 2008 at 12:51 PM
BLACKOP555
  • 10,386 POSTS
gas in the oil not good, try to burn it with a lighter, if it burns theres gas in there and you will want to change that right away and not run it.
wouldnt have anythign to do with the short running.
i think it may be in your ignition ssytem causing the cylinders to flood with fuel and be forced pass the rings and into the crankcase.
check for leaky injectors also.
Oct 22, 2008 at 12:57 PM
