2001 Mercedes Benz SLK320 Slack in rear differential or tra
59,321 MILES • 6 CYL • 2WD • AUTOMATIC
1GATOR2FINGERS
I have a 2001 SLK320 Mercedes (automatic).....when coming to a stop at a red light and then accelerating again I notice a slackness in the engagement.....when I alternate between deacceleration and acceleration quickly there appears to be a slackness in the drive train.......I also have noticed a very slight oil leak coming from the rear differential.......otherwise when the car is under normal acceleration on the highway there is not a problem......any idea what the problem is or whether I should be concerned .....the car has had it's regular maintenance checks and has 59321 miles......Thanks For Any Insight
Sep 27, 2008 at 2:40 PM
GFIMOTORCARS
  • 673 POSTS
If the problem you are describing has indications of mechanical failure, i.e. noise, vibration, clunks, then I would check the flex disks (MB replacement for driveshaft yokes). Are they cracked or damaged? If mechanically everything seems fine then I would go to the TPS sensor. I have seen these sensors loose their ability to ramp up smoothly causing slow, erratic throttle response.
Jan 3, 2009 at 12:56 PM
