2001 Mercedes Benz SLK320 A/C keeps cutting out
2001 MERCEDES BENZ SLK320
SAHACAR
Air Conditioning problem
2001 Mercedes Benz SLK320 6 cyl Automatic 89,000 miles
The Air Conidtioning in my Mercedes keeps randomly cutting in and out. Is this a problem that I can fix on my own?
May 3, 2009 at 5:59 AM
2CARPRO JACK
  • 11,533 POSTS
It sounds like it may be a little low on charge.Does it blow cold when it is working? sometimes the systems will shut off momentarily to keep from freezing the system. Having a set of gauges put on the car will tell if it is low on charge and may just need a service (vacuum down and recharge)
May 4, 2009 at 1:11 AM
SAHACAR
Thank you so much for your reply.
Yes, it does blow cold air. It doesn't seem to be the temperature that's the problem. I tried playing around with it today. When I first turn on the A/C it doesn't work, but then after about 10-15 minutes of having the car running, it will blow out air and then turn off again.
Does this still sound like it's low on charge? Could it also be the fan itself?
Thanks again!
May 6, 2009 at 5:37 AM
2CARPRO JACK
  • 11,533 POSTS
If the blower doesnt come on right when you turn it on, you have other problems.But it does sound like the system may be a little bit low, when the engine gets warm, the pressures come up a little, which may be enough to turn the system on
May 6, 2009 at 7:12 AM
