1995 Mercedes Benz SL500 ARS and engine light on
JPLJ44
Engine Performance problem
1995 Mercedes Benz SL500 V8 Front Wheel Drive Automatic 100k miles
The ARS and engine lights are both on. Sometimes, the ARS light is going off. When the ARS light is off, the car runs perfect. When it is on, you have to push on the accelorator twice as hard as normal. Right now it is intermidant. Sometimes the ARS is on, and sometimes it is not. However, the engine light is staying on all the time. Thanks in advance for any help.
Sep 1, 2008 at 12:20 PM
JACK PORTER
  • 6 POSTS
The '95 SL500 has several relays located behind the carpet in the area behind the seats. It sounds like one or two of them are malfunctioning. I had a similar problem a few months ago. You will have to have the car check with a diagnostic code reader. The loss of power is a safety feature of the ASR system. It reduces the output of the engine whenever the car thinks it's losing traction.
Good luck!
Let me know how it works out...
Dec 20, 2009 at 4:46 PM
