1994 Mercedes Benz SL500 Drivers seat
1994 MERCEDES BENZ SL500
92,000 MILES • V8 • 2WD • AUTOMATIC
EDWMORGAN
For unknown reasons the drivers seat when all the way forward and is stuck in that position. None of the adjustment controls work. The passenger seat works fine. The driver seat fuse is OK. The forward motion of the drivers seat began after driving through a large puddle of water. At first the forward motion of the seat could be stopped by pushing the control to the rear but when the control was released the seat continued to move forward. Now nothing works.
How do I fix it (I'm presently in Mazatlan, Sinaloa, MX with no MB dealer. The seat is too close to the steering wheel for me to drive the car safely. Is there a way I can disconnect the seat and move it aft manually?
Thanks for your help!
Ed Morgan
Nov 30, 2009 at 11:28 AM
MIKE H R
  • 3,094 POSTS
you will have to undo the four bolts holding the seat down. Disconnect the electric connection. Once the seat is out then you will have to turn the movement adjusting screw manually. When you have the seat at the right location I would leave the electrical disconnected. as it might do the same thing. I think you may have gotten water in the electrical controls on the seat.
Dec 1, 2009 at 2:28 AM
EDWMORGAN
Thanks for the response. Are the four bolts you are referring to all located at the aft end of the seat track as I can get access to any up forward.
I will try and remove them tomorrow and let you know if I have any problems.
Ed Morgan
Dec 1, 2009 at 7:04 AM
MIKE H R
  • 3,094 POSTS
there are two bolts holding the front of the seat to the floor, with the seat being so far up you might have some menevering to do to get them out. Once you get the seat out try to bench test the seat to move
Dec 4, 2009 at 2:48 AM
