1994 Mercedes Benz SL500
DAVE GRAY
  • 1994 MERCEDES BENZ SL500
Engine Performance problem
1994 Mercedes Benz SL500 V8 Two Wheel Drive Automatic
Monday, July 21st, 2008 AT 4:13 PM
GFIMOTORCARS
  • 673 POSTS
You may be experiencing a crank shaft position sensor that is failing. When this begins to fail your vehicle will begin to hesitate and act irradic on acceleration as the vehicle looses the position of the crankshaft. Eventually the sensor will have a hard fault and the vehicle may begin to stall.
Saturday, January 3rd, 2009 AT 10:47 PM
TREVOR JONES2
I own the exact car and HAD the exact trouble, WHEN I changed the crank, cam, and coolant temp, NO CHANGE, then was told this model has deteriorating engine wire harness, also I changed STILL no change, BUT THEN I changed BOTH distributor caps, and rotas. ALL FIXED. REMOVE one of your dizzies and look for wear. Good luck
Tuesday, March 7th, 2017 AT 10:10 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,336 POSTS
Hey,
Great addition to this thread! Please feel free to help out on the site whenever it can add information that will help.
Best, Ken
Friday, March 10th, 2017 AT 11:31 AM
