1991 Mercedes Benz SL500 Transmission Skips
JON MINX
  • 1991 MERCEDES BENZ SL500
  • V8
  • 120,000 MILES
Hello, I have a 1991 500SL that comes with a 4 gear auto transmission with a standard second gear start.
Under full throttle the transmission downshifts to 1st gear and stays until redline then it upshifts to 2nd and then upshifts pre-maturely again to third. It's like 2nd gear is almost skipped, it's a very swift upshift from 2nd to 3rd that the engine takes time in order to cover the missed out power/speed needed to be acheived in 2nd before upshifting to 3rd.
Also when in 1st gear and under full throttle, the engine's revving sounds louder than the actual acceleration rate of the car.
Oh and I'd like to add that occasionally the gears won't change when shifting from D to 3, 2, B. Unless shifted back and forth again from D to B (which is 1st gear).
What can I do to fix this problem
Monday, March 24th, 2008 AT 6:24 PM
SAMER_R
First u have to chek the fluid then adjust the cable from the gear to the idle speed. Then u have to remove the valve body and clean it and chek if there is a valve is not move or is there an broken spring.
Monday, July 7th, 2008 AT 2:12 PM
