1986 Mercedes 190E Instrument Noise
1986 MERCEDES BENZ
RICKY007
When i drive and reach 25-27 mph, a noise starts to creep behind the instrument panel, sounds like something turning, and gets louder as soon as I reach about 60. It sounds so loud like a shrieking buzzer adn then it stops and then quiet....whew! then it dosen't come back but once in a while. Sometimes if I don't drive my Benz for a while...it starts up again???? I want to fix this before something major might break behind the instrument panel.
Mar 20, 2006 at 9:19 AM
  • 55,673 POSTS
The problem is the speedo head is going bad or it need servicing. (lube)
Mar 22, 2006 at 7:42 AM
RICKY007
Thanks for the reply....could you expand on the speed head?...location so I can lube it. Thx, ricky
Mar 23, 2006 at 1:14 AM
  • 55,673 POSTS
sorry speedo, short for speedometer
Mar 23, 2006 at 2:22 AM
Suggested Repair
Service or lubricate the speedometer head. If the noise returns, the speedometer may be failing and should be repaired or replaced.
Conversation Summary
The owner of a 1986 Mercedes-Benz 190E 2.3 reports a turning noise behind the instrument panel that starts around 25-27 mph, grows louder near 60 mph, then stops and returns only occasionally, especially after the car sits. The expert says the speedometer head is failing or needs lubrication or servicing, but does not provide a location or procedure.
