2001 Other Mercedes Benz Models engine revs
2001 MERCEDES BENZ
PIERREPATRUN
Engine Performance problem
2001 Other Mercedes Benz Models 6 cyl Manual 423000 miles
Hi, may be you could help me out.
make mercedes model actros 4143 manufacture 2001
problem, from 1 gear to 3 low gear the engine at full pedal revs up to 2300 rpm and from gear 3 hi the engine at full pressed pedal revs only up to 2100 rpm
2 problem this truck has a mounted crane and when i operates the levers of the crane the engine revs still remain at idle which is 600 rpm. engine revs isn't accelerating.
please give me a reply may be they could fix my truck.
Aug 6, 2010 at 6:39 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Is this crane driven hydraulically by an engine pump or is it electrical?
Mark (mhpautos)
Aug 7, 2010 at 12:20 AM
PIERREPATRUN
it is driven by a hudraulic pump
Aug 7, 2010 at 5:20 AM
  • 31,937 POSTS
From my experience with similar units, you either set a hand throttle or there is an engine governor that control revs to ensure that the pump is fully powered, what do you have?
mark (mhpautos)
Aug 7, 2010 at 11:28 AM
PIERREPATRUN
this truck is a mercedes actros 2001 model and with the fuel pump there isn't any throtles like older trucks neither for truck it's self.
what about the engine revs that from 1 low gear till 3 low gear the engine while driving the truck revs up to 2300 rpm and from 3 hi till 8 hi the engine revs only up to 2100 rpm ?
Aug 8, 2010 at 4:29 AM
