1996 Other Mercedes Benz Models Leaking water
1996 MERCEDES BENZ
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLARE
I have 1996 C220. I am trying to figure out why my car is leaking water. it seems to only leak water when the car is off. I have already check the hoses and they seem to be all ok. I was thinking it might be the water pump but i was told if it the water pump that is not working, the car would leak when it on. So what should I do?
Oct 17, 2008 at 5:18 AM
SW8_2DG
[quote:93dfb05e71="Blare"]Engine Cooling problem
1996 Other Mercedes Benz Models 4 cyl Two Wheel Drive Automatic 145000 miles
I have 1996 C220. I am trying to figure out why my car is leaking water. it seems to only leak water when the car is off. I have already check the hoses and they seem to be all ok. I was thinking it might be the water pump but i was told if it the water pump that is not working, the car would leak when it on. So what should I do?[/quote:93dfb05e71]
freeze plug
May 27, 2010 at 1:29 PM
